All drawings must be flattened into a single layer
jovenm_2000
Observer
jovenm_2000
Observer
Observer
Hi. I'm working on drawing submission & one requirement is that 'All drawings must be flattened into a single layer'
Does this mean that they only need to see one layer on my drawing then flatten? I know the command flatten.
0 Me gusta
Responder
Soluciones aceptadas (1)
768 Vistas
6 Respuestas
Respuestas (6)
Valentin-WSP
Solución aceptada
@jovenm_2000 ,
Welcome to the forum.
Instead of guessing what the "requirements" mean, ask the client to elaborate.
It may mean making all objects/element in AutoCAD flat - using the FLATTEN Command, and on one layer (highly unlikely) - but why guess.
Or maybe this...
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
pendean
Community Legend
Community Legend
@jovenm_2000 Why are you asking us what "they" want?
Since you seem unsure... I suspect your jurisdiction is actually asking you to do this to your submitted PDF drawings (which has nothing to do with AutoCAD BTW) https://myresearchpath.duke.edu/quick-reference-guide-how-flatten-pdf
https://pdfpro.com/blog/guides/how-to-flatten-a-pdf/
https://www.printivity.com/insights/what-flatten-pdf-file-means-and-how-to-do-it/
HTH
paullimapa
I’m sure they’re referring to pdf not dwg so make this adjustment to your Dwg To Pdf.pc3 device before generating any PDFs:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-turn-off-la...
Paul Li
IT Specialist
@The Office
0 Me gusta
pendean
Community Legend
Community Legend
We have yet to encounter a US based Governmental Jurisdiction already hell-bent on 'flattened' PDFs accepting the results from AutoCAD with that method, that still have 'something" they find and object to fiercely.
paullimapa
Time to work in the city of LA. Just helped a friend submit a set of PDFs with the flattened requirement from using AutoCAD and all went through without a hitch
Paul Li
IT Specialist
@The Office
ChicagoLooper
Is your site LA County, California? Or in Canada?
Flattened drawings are typically done to put all objects at Z=0, or all entities at mean sea level.  By placing all objects on the same drawing plane, distances can be accurately determined from plan view.
If your drawings only need to measure horizontal distances the flattened command will allow a user to ignore Z-values and only consider the X- and Y-components of distances.
Foe example, if you have two adjacent points in a drawing, the dimensioned distance between them might be 24.6.meters. On the printed hardcopies, though, they only ‘appear’ to be 3.5 meters apart. Why? Because one point is at the top of a waterfall and the other at the bottom. Or on top of a building for one point and on the sidewalk for the other.
Flattening a drawing using the flatten command doesn’t mean to put objects on a single layer, it means to out all objects on the Z=O plane or to ‘remove’ all elevation from the drawing, to make it flat. The layers can remain at status quo.
If you draw using Civil3D, this might, or might not, require extra steps in addition to using the flatten command, especially if you create TINs b/c surface elevation is critical to your scope of work, such as final surface grade and water drainage.
Does your office produce engineering type plans and do you frequently require agency approval for those plans?
Chicagolooper
