All Autodesk products will not recognize GPU
ptitleman
Message 1 of 8
ptitleman
I mainly use Plant3d 2024 right now.  When I booted up Monday morning, the software was no longer recognizing the GPU, so hardware acceleration was turned off, and was grayed out.  I then opened regular AutoCAD 2024, and it had the same problem.  I then downloaded Plant3d 2025, which also had the same problem.  Everything in the pc seems to show the GPU is working.  We made sure all the drivers were updated.  I also did google it and tried everything out there to reset it, to no avail.
Any recommendations would be greatly appreciated.  Thank you!!
Replies (7)
Message 2 of 8
Valentin_CAD
@ptitleman ,
See if this helps:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 8
paullimapa
@ptitleman Try this possible solution
Paul Li
IT Specialist
@The Office
Message 4 of 8
ptitleman
yes, that was the main list I found.  We went through all of that, but nothing fixed it.
Message 5 of 8
ptitleman
Thank you, that link did not work though.
Message 6 of 8
paullimapa
I updated it. Try again
Paul Li
IT Specialist
@The Office
Message 7 of 8
ptitleman
Thank you.  We did find that page yesterday as well, and we tried those with our IT service.
This is the only part we did not try, as we could not find this option when right-clicking on autocad
  1. Right-click on the Autodesk software and choose Run with graphics processor > Change default graphics processor...
    Alternatively:
    1. Right-click the desktop and choose NVIDIA Control Panel.
    2. Click Manage 3D settings on the left and then click the Program Settings tab.
Message 8 of 8
pendean
Community Legend
Community Legend
    Alternatively:
Here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
