Anuncios
aligning text independently
No aplicable
I'm working with a CAD floorplan that shows room numbers and I need to show the square footage of each room below.  I'm using MTEXT to show each room number and square footage, each on their own respective layers.  I was wondering if there is an easy way to align the square footage under the room number with uniform spacing.  I tried using the TEXTALIGN command, but that just lines up each MTEXT along a single line, and evenly distributes them.  Since the rooms vary with the positions, I need to have each square footage MTEXT align underneath a respective room number.
Thanks.
0 Me gusta
Responder
Soluciones aceptadas (1)
365 Vistas
3 Respuestas
Respuestas (3)
john.vellek
Solución aceptada
Hi stcampi4 and Welcome to the Forums!
I suggest a better way to accommodate this would be to use Attributes in a block to create your room labels and area tags. Each attribute can still be on a unique layer.
I have attached a sample block so you can try it out.
The nice feature about having it in a block is the text is always aligned properly and you can also data extract the information into a table or schedule if you need to.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
0 Me gusta
No aplicable
Going with blocks is the ideal situation as John pointed out.
If you can't do this you could use a LISP that set the MTEXT to some type of CENTER justification and then matched the position based on rotation/location.
But a block would be so much easier...
0 Me gusta
john.vellek
Hi stcampi4,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
0 Me gusta
