Aligning Multiple Objects
Message 1 of 8
How we can align multiple objects in Autocad together ?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Command _ALIGN (>>>details<<<)?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
It is not working with multiple objects.
Message 4 of 8
Alfred.NESWADBA
For me it can work with multiple objects.
Looking to your screenshot it says, that you have 29056 objects selected (that is like "multiple", isn't it)
Jut the last line tells you, that you have selected one object twice, that is rejected then.
- alfred -
Alfred NESWADBA
Message 5 of 8
Thank You
Message 6 of 8
How can I export the new file and keep the new alignment.Smiley Happy
Message 7 of 8
Alfred.NESWADBA
Sorry that I don't understand that question. After aligning the objects they have a new position, same es command _MOVE, _ROTATE or _SCALE ... just save the drawing, same as after moving a line.
It might also help what type of "export" you mean?
  • Export to another CAD-format ... use command _EXPORT
  • Export parts of your drawing into a new DWG ... use command _WBLOCK
  • Export to anything else ... please let us know the format you'd like your geometry to export to
- alfred -
Alfred NESWADBA
Message 8 of 8
Kent1Cooper
@Alfred.NESWADBA wrote:
It might also help what type of "export" you mean? ....
Another possibility, to "export" the entire drawing to another drawing file in the same version:  SAVEAS if you want to be taken into the new drawing, or if you want to remain in the source drawing, SAVE [typed in, not via any so-called "save" menu item or ribbon icon or Ctrl+S, all of which really give you the QSAVE command].
Kent Cooper, AIA
