I'm really hoping you guys can help me as I haven't gotten great advice yet. Let me preface by saying I'm a newbie so lay-man's step by step help would be helpful (I've been getting a lot of "just do it" kind of help from other sources).
I am trying to parametrically draw A V-slide plate. I have all the constraints in EXCEPT- the linear distance between the 2 parallel lines should be 1.625. No matter what I do whenever I try to enter this constraint I loose my tangents.
Also, can someone explain the difference between a linear constraint and an aligned constraint? Either one I use I cannot get the constraint value to match the value in the dimension (I just have the dimension in there for now so I can see if the constraint matches the dimension). I have been playing around with the shift>right click to bring up more constraint point options but I get a lot of errors when I use that.
Also, the center point of the bottom right radius needs to be 1.375 away from the vertical center. I had that set earlier but when I trimmed the circle, now it is off. What constraint would I use to reset it? I tried linear but I got an invalid point error when I tried to select the center point of the radius.
Any help or resources you have, I would be eternally grateful.
Thank you,
Abbey
