Aligned lines showing as moved when zoomed in much
hussicharmssf
Message 1 of 11
hussicharmssf
Hi. When i zoom in very closer the lines which seem to be on same level appears to be moved a little bit. can anybody provide a solution to this issue. i have attached the drawing here and marked the places with issue in a revcloud. u can zoom those areas and see the problem.
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
What revclouds?
Which lines?
Message 3 of 11
Patchy
You meant the red line on top of the gray line,it's not ortho so you see it moves when you zoom in really close.
Message 4 of 11
JBerns
@hussicharmssf,
Could you create a Screencast video that demonstrates the behavior you describe?
Autodesk Screencast
AutoCAD version? Updates? Video card? Graphics driver version? Screen resolution?
Can you reproduce the problem in other drawings? Reproduce problem on other computers?
My first guess would be that it is a behavior of your graphics driver.
We look forward to seeing the Screencast.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 5 of 11
hussicharmssf
i have put one revcloud at top left of carparking and another one at door..zoom very very in those areas and u can see the lines are not aligned on same line..they seem little bit moved from one other. even if i try to grab the end pointt and align with other end point, again the lines are not aligned...
Message 6 of 11
hussicharmssf
hai jberns. i have given the link to the screencast.kindly see it. am using autocad 2017.nvidia geforce 4gb. u can see in the video when i zoom very close the lines are not aligned
Message 7 of 11
hussicharmssf
see the screencast here
Message 8 of 11
vinodkl
Hi @hussicharmssf
There is no need to use the command "MOVE" you just need to select the grip and snap to the endpoint. When you use the command "MOVE" you are moving the whole rectangle created on layer "hatch" and when it's moved and snapped to one end its moves away from the other end.
Also, I noticed that the "PLAN" is slightly rotated. Use the command "PLAN" and select "Current UCS" to correct it.
Use "ortho" (F8 key) when drawing lines that are horizontal and vertical and use object snap (F3 key) properly and snap the lines to the correct endpoint so that this issue doesn't arise 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 9 of 11
imadHabash
This is a drafting issue that can be fixed simply :
  • Move the two car parking away .
  • make sure now that you have a clean space ( Ortho Lines) and dimensions for the space ( Car Parking ) .
  • check now your two car parking lines and dimensions .
In this way you will not see again those shifted lines .
Imad Habash
Message 10 of 11
hussicharmssf
how can i  see this details?
Message 11 of 11
vinodkl
@hussicharmssf  select the object and the type in the command "LIST" to get it.
