This may have been asked before but I'm not sure what the function is called so I will try my best to explain it.
I am on AutoCad 2019 on an MSI Laptop.
When drawing a line I used to be able to hover over an existing point, once the snap is shown I drag the mouse over and type in 6" (for example), and the beginning of my line starts 6" from the established point, then I can carry on with the rest of my line work.
My hang up is when I type in 6" and hit enter, the start of the line picks a random spot, sometimes even picking different random spots upon repeated tries of the same starting point and same dimension input.
This use to work, now it does this. What am I doing wrong?
Edit: Ok so after messing around a bit, I have found that if I type 6" (again, for example), and do not move the mouse, the extension line created goes away and picks a seemingly random spot. I then have to, after typing in the dimension, start the process over again and hover over the existing point and drag in direction I want, then hit enter.
So My question has changed slightly,
Why is it doing this now?
