Align command
Align command
rogermd
Align command
rogermd
I have posted this yesterday in the wrong forum. Recently i found that the ALIGN command does not work anymore or maybe it doesnt work in 2015 at all as this is the first time i used it again after upgrading to 2015 a few months back. But yesterday, i uncheck everything in the OSNAP setting except for the normal Obejct Snap (F3). and it works after i restart Autocad. But after I restart again Autocad again, it doesnt work again. Below is the message from my command line.
Command: _align
The file geom3d(.lsp/.exe/.arx) was not found in your search path folders.
Check the installation of the support files and try again.nil
I think i also found the same problem here but no solution so far. Any help is greatly appreciated.
Best regards
Soyoung.H
Hey,
There could be 2 possible reasons which cause this problem.
1. Anti-virus program or disk managing program
: these applications often block AutoCAD to access certain files or registries. If the blocked file is related to launching AutoCAD, you may get this problem. It would be fixed by "reset to default" once, but the file will be blocked or corrupted again by those tools.
2. Virus issue
: For more information, please read these articles.
AutoCAD and Viruses
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD...
VBA projects embedded in drawing files create potential macro virus risk
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/VBA-pro...
How to detect and remove the Acad.vlx virus
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
ACAD/Medre.A Malware FAQ
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/ACADMed...
AutoLISP and VBA Security Controls in AutoCAD 2013 SP1
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoLIS...
Soyoung.H
rogermd
Sorry for the late update. I havent got the time to really check the bits and pieces of it but i just include the crx file in the start-up suite and that solves the problem. Thanks for the reply.
Best regards,
