I know this is an older request for ALING and I do not see any answers here.
ALIGN used to be used to ALING and SCALE your drawing at the same time.
My 2024 and 2025 does not allow that to happen any more.
This is my options for ALIGN: Type Align: Pick Point then Justification comes up L/C/M/.R <NO Change>
When I pick the first point it goes right into these other commands and can not get a second point option.
I know I can rotate, scale up etc but ALIGN used to do the job in one step.
Any help would be greatly appreciated!!
Side note... used to always put a - before the command to get the old way of doing the command and many comments come up when someone puts a _ before the command saying that must be a typo.
Well, don't know when AUTOCAD made the change, but some commands will start with the - and some will start with the _ . Align must be _ . But Plot must have the - . If you use _plot it pops up the dialog box. -plot will be the old school way of typing. So when you see a - or _ both could be right depending on the command being used.
JRR!
