ALIGN command dosen`t works for imported pdfs
kubastan89
kubastan89
I imported PDF file using PDFIMPORT command and then I want to scale the pdf using original coordinates with ALIGN command.
I choose first and second source and destination point, continue and allow to scale it and it dosen`t transport the drawing to proper location.
I marked the coordinates with pink circles. X coordinate starts with 7.... and Y starts with 5......
Please have a look why ALIGN command dosen`t work properly.
0 Me gusta
Responder
Soluciones aceptadas (1)
512 Vistas
6 Respuestas
Respuestas (6)
imadHabash
your elements too far from 0,0,0 .... would you try to move it near to 0,0,0 then see if any changes.some times (almost) when you work too far from 0,0,0 such a problems will appear.
Imad Habash
Vinayv4v
I am getting the correct co-ordinates when aligning.
Cheers,
Vinay Vijayakumaran
kubastan89
Please have a look at recorded screencast:
https://knowledge.autodesk.com/community/screencast/72180268-4c45-448a-897b-6c64e1f2378e
Still I get incorrect coordinates.
0 Me gusta
Vinayv4v
Can you please attach the pdf so that I could give it a try.
Cheers,
Vinay Vijayakumaran
0 Me gusta
Vinayv4v
Solución aceptada
I am getting the correct result when aligning.
But when I turned on the Dynamic Input (as shown in your screencast) I am getting the same result as you get. (Getting wrong coordinates)
Turn off the DYNAMIC INPUT (F12) and and give it a try.
You will get the correct result.
Cheers,
Vinay Vijayakumaran
0 Me gusta
kubastan89
Strange things :cara_con_la_lengua_fuera:
After implementing your suggestions I got the correct results. Thanks a lot.
