After trying to convert pdf file to dwg and failing my ssd disk is fool.
2017_12062
2017_12062
After trying to convert pdf file to dwg file autocad froze. I turned off my computer and when i turned it on my ssd was full. Does anybody know what happened?
Valentin_CAD
@2017_12062 ,
Sounds like you need to clear some space, hence the reason your AutoCAD froze.
Review all the suggestions on the following links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
2017_12062
Thank you for answering! I figured it out. AutoCAD was making huge temporary files in app data folder.
Valentin_CAD
@2017_12062 ,
Great! Glad the links worked-out.
Emilio Valentin
Type a product name
