After I enable the moving along X and Y axis function, the application got very laggy, How do I fix it?
sityeechun
sityeechun
Now when I select the object, two arrows appear on the object which allows me to move it along Y and X axis. The Y axis arrow being green and X axis arrow being red. How do I turn this off? The lag is really unbearable and would like it to stop as soon as possible, any assistance is appreciated.
0 Me gusta
Responder
Soluciones aceptadas (2)
201 Vistas
2 Respuestas
Respuestas (2)
vinodkl
Solución aceptada
Hello @sityeechun
It sounds like you may have switched to a different visual style. To help resolve this, try typing the command "VS", then press "2" and hit "Enter" to switch back to the "2D wireframe" style. I hope this solution makes things easier for you!:cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
Solución aceptada
Hi and Welcome to AutoCAD Forum,
You may need to change your CAD visual style ( as mentioned above ) .. Click on below image to see how fast will reolved.
Imad Habash
0 Me gusta
