- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Have a project that I'm struggling with performance issues.
When opening the file and all the xrefs/ layer states etc are loading I notice on the command line various AEC things also being loaded.
Wondering if this could have anything to do with third party contractor files.
I have autocad architecture so can read the files.
This project had a 3rd party contractor generate as builts from 3d scans of the building and the files were converted to autocad.
Wondering if something could be buried in these files that needs to get unloaded somehow.... all I need is the 2d linework.
So far the only thing I've stumbled on that is 3d is some polylines.... which I didn't even know existed..... I mean what can they be used for anyway?
Select all and nothing appears to be at different elevation than zero.
Ran some command (can't remember the name) to put everything at zero but did not run the flatten command because I've had issues resulting from running that command in the past so kind of avoid it.
Thoughts?
