looks like you have issues with the permission of the files or folders you try to save to.
Try for a testperiod of a few days (depending on how often you get the error message) to save the file on your local disk (and on the end of the day copy the files to the server so the data get's archived.
Another reason might be the antivirus software you use. If you can disconnect the workstation from accessing internet you might try to disable your antivirus software and see if the issue again appears.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
