advanced render settings
I can not seem to find advanced render settings. What am I missing? I am running autocad 2017. I have no problem opening up the render presets but i can not seem to get to the advanced render settings.
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Which settings are you missing, are you looking for?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I can't seem to find the advanced render settings palette for autocad 2017. Did they remove it?
Sent from my iPhone
Alfred.NESWADBA
...compared to which version of AutoCAD?
The palette "Advanced Render Settings" from AutoCAD 2015 or earlier does not exist any more as this palette hold the settings for Mental Ray rendering engine. AutoCAD 2017 is based on a different render system (they call it Rapid RT), this has less configuration settings and so the settings you are used with Mental Ray do not exist any more or are placed in other dialogs ==> that's why I asked which setting you are looking for. 😉
- alfred -
Alfred NESWADBA
good to know. thank you for the info.
Thank you!
