Adding Save or QSave to right click menu
lee.pellegrin
lee.pellegrin
First, I would like to know if save and save do the same thing.
Second, I would like to know how could I add qsave to my right-click menu instead of having to key in qs every time I need to save.
pendean
Community Legend
Community Legend
@lee.pellegrin In full AutoCAD, SAVE lets you create a second DWG file without ever leaving the file you are in. Nothing more. Your current file remains unsaved.
QSAVE simply "saves" your current open file. Nothing more.
In the LT versions of AutoCAD, both behave like QSAVE.
HELP in both programs explain it all if you need to do a deep dive.
For your second query, these online videos are easy to follow
https://www.google.com/search?q=how+to+add+qsave+into+the+autocad+right-click+menu
https://www.google.com/search?q=how+to+add+a+command+into+the+autocad+right-click+menu
Patchy
paullimapa
The way I remember the SAVE feature is it’s like making a copy of the current drawing when you give it a different name.  Whereas SAVEAS creates a copy and ends up in that dwg. QSAVE is the fastest because no dialog appears for user input and current dwg is saved with a backup file created
Paul Li
IT Specialist
@The Office
