I've attached picture for reference.
I have a line of text that should be centered in the space allotted. As soon as I add brackets, commas, etc the text itself aligns with the top of the bracket, but in doing so shifts the sentence up slightly, therefore making the letters no longer 'actually' center within the space, even if the text block itself is.
As you can see very clearly in my attached example, I have a line of text aligned to MC, but the top of the text is now aligned with the top of the bracket leaving a larger space under the text making it no longer centered within the upper and lower lines.
My question is, Is there a way to make it so the parentheses bracket, when typed, is center aligned with the text and not top aligned as pictured. I've tried everything to do with actual "alignment" tools but nothing is working.
Thanks, in advanced, Evan.
