Adding leader points, pressing enter/continue creates a point at origin.
MaccyDee
Message 1 of 18
MaccyDee
cant tell if this is a bug/feature/variable.
When im adding leader points;
  • I right click the leader
  • click add leader
  • select the new point(s) for the leader
  • then if press enter or continue it will create another leader point at the origin but will only do this once per "add leader" session.
  • i.e if I press enter again it gives me another leader to place, but then enter again, ends the command (how one would expect the first time pressing enter would behave)
Replies (17)
Message 2 of 18
imadHabash
For adding more leaders for the same point, you have to use the mouse button for that. Click on below image to see how it works....
Imad Habash
Message 3 of 18
MaccyDee
My problem is, after I finish setting the leader points and hit enter to cancel/continue, it will place a leader point at 0,0, only if I press enter again it cancels the command like it should.
I'll try get a screen recording tomorrow.
Message 4 of 18
pendean
Community Legend
Community Legend
<ENTER> works fine here to end the MLEADERADD tool in AutoCAD 2025.1.1 in Windows: does this happen in all of your files or just this one?
Are you on a MAC and running the MAC version of AutoCAD by chance @MaccyDee
Or are you running a 3rd party add-on, or using a vertical variant of AutoCAD2025?
Message 5 of 18
MaccyDee
standard AutoCAD 2025.
I've checked using the regular acad template and leader.
It doesn't do it using the standard leader.
If i copy one of the leaders from my template >into> the acad template and try it again, it will do it, the standard leader still works as it should.
standard leader in my template does the same thing (enter sends to 0,0)
I've tried audit, tried export to AutoCAD, tried redefining the leader style,
Attached template.
Message 6 of 18
paullimapa
And you’ve downloaded and installed the 2025.1.1 update?
Paul Li
IT Specialist
@The Office
Message 7 of 18
MaccyDee
i believe so, have a faint memory of doing so and  there's no updates available through the app
Message 8 of 18
paullimapa
To check in AutoCAD enter command ABOUT, do a screenshot & share that here
Paul Li
IT Specialist
@The Office
Message 9 of 18
MaccyDee
Message 10 of 18
james8EPS2
I am having this same issue. I am running AutoCAD 2026.0.1
If I add a leader to a standard multileader and then press enter, the command exits as normal.
If I add a leader to a custom multileader and then press enter, AutoCAD adds a leader at 0,0 and the text window says "invalid input". If I press enter again, the command exits as normal.
Please see the attached video clip showing this behavior.
Message 11 of 18
pendean
Community Legend
Community Legend
DWG file please @james8EPS2
Message 12 of 18
james8EPS2
Here you go.
Message 13 of 18
pendean
Community Legend
Community Legend
2023
2025
2026
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Contacting-a-techn...
Message 14 of 18
james8EPS2
Thank you.
Message 15 of 18
james8EPS2
Just to let anyone else who experiences this issue know, I did submit this issue to Technical Support. Technical Support investigated the issue and forwarded it to Development, so it's possible AutoCAD will revert to it's previous behavior after a future update. Technical Support revised and updated this article about the issue:
When adding a leader to an existing multileader, an extra leader starting from the origin is added i...
which outlines two partial workarounds (other than hitting ESC instead of Enter after placing a leader).
I hope this helps, and thank you again pendean.
Message 16 of 18
pendean
Community Legend
Community Legend
@james8EPS2 Thank you for the follow-up.
Message 17 of 18
davidschnegg7
Thanks for reporting this.  It's been driving me crazy since updating to Acad2026.
Message 18 of 18
Julio_Soto
I'm here for the same issue. I'm about to reinstall AutoCAD
