Adding attribue which display level value automatically
arbin.singh143
arbin.singh143
Hello Everyone, I have block name Tms with attribute length and breadth.I want to add level attribute to existing tms block which display level automatically. Is it possible to do so ???
imadHabash
 you can edit ( modify ) your existing block and add text attribute with field that display level automatically .
Imad Habash
vinodkl
Can you tell us what does "level" means in the question?
Can you show us the snapshot or attach the drawing, so that we can help you out?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
vladimir_michl
If you refer to an architectural level, you can use a computed field to display the level value - see an example here:
https://www.cadforum.cz/catalog_en/block.asp?blk=9749
https://www.cadforum.cz/cadforum_en/elevation-label-with-automatic-text-of-level-and-elevation-tip90...
Vladimir Michl, www.cadstudio.cz
