Adding an attribute to mtext
I am trying to add an attribute mid-sentence or add an attribute with a prefix and/or suffix. The idea being that only the numerical value is part of the attribute. For example:
Length: 12.000m
I only want the 12.000 to be the attribute so i can then add it to formulae etc. At the moment the attribute is reading as 'Length: 12.000m' and thus will not work in my formulae.
Thank you in advance.
Daniel
Replies (9)
dbroad
You can add a field but not an attribute mid mtext. To do that, right click at the point you want to add the field.
Attributes are for blocks. Mtext can be an attribute but an attribute cannot be embedded into mtext except by creating 2 separate mtext strings inside a block with the attribute between them. This only works if the attribute value will be extremely restricted in width.
Architect, Registered NC, VA, SC, & GA.
john.vellek
Hi @Anonymous,
Is it possible use a Field to capture the length value (minus the units) so you can place that in the Mtext?  Do you have a sample drawing that contains the Mtext and the geometry you are using?
John Vellek
jerry_swain_work
Observer
Observer
I just tried this very thing. I have an attribute and I want to add its value to a MText object. Here are the steps I used:
  • open the block editor
  • select the MText
  • open mtext editor
  • chose "Insert Field"
  • chose "Object" under "Field names:"
  • selected my attribute
  • under "Property:" chose "Value"
  • Under "Format:" chose "Uppercase"
The default value populated in the MText and I saved/closed the block editor. I double clicked the block and edited the attribute. The default value was still showing, not the new value. I reopened the block editor and changed the default value of the attribute, and saved the block. The the new default value showed. But after closing the block, editing the attribute did not change the text. It seems as though the "field" was not dynamic. Am I missing something?
cadffm
it seams you missed the basics about block/structure.
>"I want to add its value to a MText object"
Doesn't make sense, because the Mtext is part of the block!
Each Blockreference would show this value, because there is just one Mtext,
but you can have multiple blockreferences with different attribute values.
(Attributes are attached to the Blockreference, this way it is possible that attributes can have different values per blockreference)
Sebastian
cadffm
Sample: BlockA, one Line, one MText*, (one Attributdefinition for Attribute"X")
3 Blockreferenc, with Attibut X values
Ref1: TEST11
Ref2: TEST22
Ref3: TEST33
Question: Each Blockreference displaying  the one and only Mtext, what Mtext value should appears?
Sebastian
jerry_swain_work
Observer
Observer
Yes. I know. I have a dynamic block with grips I can adjust dimensions
with, and I'd like to add the piece mark into text that resides inside the
block without bursting it. Multiple instances of the same block, with
different dimensions and pieces marks. This is the last feature needed.
dbroad
In the block definition, add an attribute with a preset flag. In the sample value, add a block placeholder field. It can access any of the block definition’s dynamic parameters. Then each block reference can vary
jerry_swain_work
Observer
Observer
Does the MText in the description above not count as a "sample value"?
dbroad
Not sure what you are referring to. I meant that you put the field in the default box along with whatever prefix and suffix text you want to add. I’m not aware of a description box.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
