Adding a new sheet size to Plot in AutoCAD
mramseur
mramseur
I need to plot a drawing on a 60"X36" size sheet of paper, but I don't see a sheet for that size under the Paper sizes.  What do I need to do?
Thank you.
Valentin_CAD
@mramseur ,
Look at this:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
jreidKVSUZ
MR, It is very easy. I have some of start steps and some you can figure out.
1. Plot and chose your printer. 2. Properties. 3. Custom Paper Size. 4. Start from Scratch then Next.
5. w 60 h 36  Next 6. leave .25 or change it Next. 7. Name Plotters Paper Name (default is good).
8. Name the Plotter your own name or leave it as is Next (remember what ever you do). 9. Finish.
10. Click OK. 11. Apply to what you want (the 2nd one keeps it for all times). 12. Paper Size select your paper's name (all the way at the bottom). 13. Set up all of your other needs for plotting and good to go!!
Hope this helps!!
JRR!!
