Add text to multiple similair objects
rickburgers
rickburgers
Community Visitor
Community Visitor
I trying to figure out how to add text to multiple similair objects/blocks at once.
We have a drawing with several different lightfixtures. We would like to add fixture codes to the corrosponding types.
How is this possible?
AVCPlugins
There is an AVC Mark plugin that is specifically designed for such tasks. You can place both text labels and any marking blocks. You can mark blocks and solids and any drawing objects. You can specify on the label the name of the block or any of its attributes, any parameter of the dynamic block...
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
Rob_Jensen
If they are Blocks just add the information to the block definition via the block editor. If you need that text to be edited and or extracted, then insert it as an attribute.
