Add more text to linked block attribute
Hello
I am able to link the value of one block to a second block using the Fields, Object method using the method shown at http://www.archidigm.com/Coverpage/cover4-08/lounge-set_link_values.htm.
What I seek is guidance on how to add/remove text from the source block attribute before it is placed in the second block. The source block attribute text is "V7000". What I want in the second block is only the number "7000". I also have the requirement to append text to the source block attribute,i.e, the value "V7000" becomes "7000B".
I found a reference to using computed fields without sufficient explanation on how to achieve this. I have explored using Diesel and was unable to figure out just how to modify the text.
Kindly assist with a link or detailed explanations.
regards
Paul
