Anuncios
Add More Multiple Leaders From the Current Tags
ducmap2212
ducmap2212
Is there a button can add more leader after placing a leader tag in Autocad. The right image come from Revit, I can add more leaders very quickly by using this feature.
0 Me gusta
Responder
Soluciones aceptadas (2)
219 Vistas
3 Respuestas
Respuestas (3)
imadHabash
As much as i understand your issue ... You can by multileader options ( Add/ Remove ) do that. >> Click <<
Imad Habash
vinodkl
Solución aceptada
Hello @ducmap2212
I assume that the tag is a multileader. If yes, then you can multiple leaders to multileader using the command "MLEADEREDIT" and select the "tag". This can also be accessed from "annotate" tab. Image fore reference.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ducmap2212
Solución aceptada
Thank @vinodkl @imadHabash
I also find find another way to do it
Just select the multileader tag --> right click --> context menu pop up --> add leader
