add decimal place in lisp routine
Hello!
I found a pretty good lisp to calculate the slope percentage of a segment and write it on a text object, but the problem is that is on absolute units and i would like to have one decimal place on it p.e.: i= 4,7% and not i=5%
here is the lisp routine:
;;Ranjit Singh
;;5/25/17
(defun c:slopefunc (/ pt1 pt2)
(entmakex
(list '(0 . "MTEXT")
'(100 . "AcDbEntity")
'(100 . "AcDbMText")
(cons 10 (mapcar '+ (list 0 (/ (getvar 'textsize) 2.0)) (mapcar '/ (mapcar '+ (setq pt1 (getpoint)) (setq pt2 (getpoint))) '(2 2))))
(cons 1 (strcat "i="(rtos ((lambda (x) (* -100 (/ (cadr x) (abs (car x))))) (mapcar '- pt1 pt2)) 2 0) "%"))
'(71 . 😎
(cons 50 (if (> (car pt1) (car pt2)) (+ pi (angle pt1 pt2)) (angle pt1 pt2))))))
Report
ok 😅 where the 😎 appears it is supposed to be the number "8" followed by the ")", hope you understand 😅
ВeekeeCZ
@Anonymous wrote:
Hello!
;;Ranjit Singh
;;5/25/17
(entmakex
'(71 . 😎
Report
Change the red figure.
thankyou very much 🙂 it is solved
