Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
add attribute to line
3 REPLIES 3
3826 Views, 3 Replies
i am trying to make a dwg file of outlines from a building.
i want to add an outline_id attribute to the lines so i can use that attribute in fme.
can someone tell me how to do this?
3 REPLIES 3
Alfred.NESWADBA
Are that multiple buildings? Or if you have just one building why are then multiple outlines excepted?
You can create an attribute, all it OUTLINE_ID, then create a block from the outline + the attribute definition so you get the dialog to fill the attribute with a value. But not sure if that is what is really needed.
When you export these borders using FME, what are you doing then with the data?
That might make it more clear about what is really needed.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Kent1Cooper
Can you use the XDATA Express Tool, to attach eXtended DATA [such as numbers or text strings or other options] to the outline elements [whatever they are]?  >Read all about it<.
Kent Cooper, AIA
in reply to: Alfred.NESWADBA
thank you for the fast reply.
making a block from oiutline and the attribute definition worked!
sorry for not being completely clear on what i wanted, but atleast i can go further now.
thank you.
AutoCAD Inside the Factory
