HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If you browse to the shortcut (mine is here: C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters\Plot Styles), you can rt-click it and select Properties.
You want to verify that the Target path is correct. It is likely that the actual executable is in "C:\Program Files\Autodesk\AutoCAD 20xx\styshwiz.exe"
Then, also check the Start in location which is likely: "C:\Program Files\Autodesk\AutoCAD 20xx\Plot Styles\"
John Vellek
