Add a hatch from another drawing
anch2304
anch2304
Hi.
I want to add and save a hatch in my drawing that i have found in another drawing. How do I do that?
cadffm
if you don't have the hatch definition, you can't.
You need a tool what can re-create the definition, but there is no function ootb.
Sebastian
WeTanks
For XFER, try using the following command?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
TomBeauford
I used GETPAT.LSP for many years but switched to model_hatch.lsp by Vladimir Nesterovsky & later updated by 'gile' a few years ago. Try them both work but model_hatch outputs to the text screen for you to copy & paste to whatever PAT file you choose while GETPAT creates a new PAT file.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
paullimapa
@anch2304 and always keep a copy of the custom .pat file and backed up with your projects that use it otherwise, you'll encounter the same problem again.
Paul Li
IT Specialist
@The Office
