I'm trying to get coreconsole to plot some files but I want it to load a profile first.
when I run my script in coreconsule it does not find the ctb sense the profile is not set.
when you run coreconsole is does not know which workspace I need it to run in. so is there a way to load a profile in a script.
Not sure if this is exactly what you are asking...
This isn't loading a profile per se, but it seems that all you really need is to set an environment variable. (And I think you can run LSP code in a script, right?)
you can Try this.
Thanks and Regards,
Hari Nair [Master From Lost Nalanda]
