Hi craigLKR6V,
Welcome to the Autodesk Community!
I assume what you are trying to do is remote into a workstation that has AutoCAD installed so you can work on drawings. If yes, then the VPN should work just fine.
If you are trying to do something else, please give me some more detail.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
I would strongly suggest that you remove your contact information from your post.
