AutoCAD Forum
Accessing and modifying Rectangular, Polar and Path array objects in VBA
2 REPLIES 2
spauliszyn
503 Views, 2 Replies
I can't seem to find how to edit properties of rectangular arrays using VBA.   Same goes for polar or path arrays.
For example, if i draw a circle in an empty drawing and then create a rectangular array using the command ARRAY, AutoCAD will typically creat a default array with 3 rows and 4 columns.  In VBA, ThisDrawing.ModelSpace.Count = 1 and ThisDrawing.ModelSpace(0).ObjectName = "AcDbBlockReference".  However, i can't see or modify any array propertiessuch as row count, row spacing, row elevation increment, included angle, etc.
Any ideas?
2 REPLIES 2
pendean
in reply to: spauliszyn
spauliszyn
in reply to: pendean
Thanks pendean. Sorry about the mix-up as correct community didn't seem to be obvious to me. I will repost this there.
Shawn
”Boost
