AcBrandRes.dll - Problem loading AcBrandRes.dll resource file
PatrickByrne
PatrickByrne
Just had this message starting on my machine, after you press okay it then gives a Fatal Error.
Only changes to the machine since I last used AutoCAD was a Windows 10 Update last Friday. Also lost my printer, the drivers do not work with my version of Windows but were fine last week.
Get the same error with AutoCAD 16 and 18.
Any help appreciated.
äcäp
Perhaps you can try to uninstall your last update through Windows - Uninstall an Update control panel. See if the driver can be rolled back and everything can work as normal state.
PatrickByrne
Unfortunately on that day Microsoft appears to have updated all of its products.
Has anyone else experienced this problem?
Alfred.NESWADBA
have you tried (as suggested) to uninstall the latest Windows updates?
I didn't, but I don't know which udpates you have got installed, also because of the plotters I don't know which printers/plotters that are and what errors you get when you try to print to them.
The more info's you give (plus feedback to recommendations you already have got) the better we can help.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
PatrickByrne
hello Alfred,
Yes I uninstalled the latest windows update but there was no change in Windows or the AutoCAD error.
Unfortunately here the same problem after the latest (big) windows update.
Somebody a solution? I guess Microsoft has changed certain permissions which occurs the problem...
Alfred.NESWADBA
Then please run a repair installation as described >>>here<<< (as admin, disabled antivirus)
Good luck, - alfred -
Alfred NESWADBA
