Acadiso vs Acadiso3d
I've been using auto cad for the past few weeks working on the 3d modelling using acadiso.dwt.
However, I just found out that there's sth called Acadiso3D.dwt.
What are the differences between those two and am I recommended to use Acadiso3D.dwt when I make on 3d objects(even though I didn't have any problem working with acadiso.dwt)?
Alfred.NESWADBA
Don't worry, you can do your 3D work in the acadiso.dwt in the same way as in acadiso3d.dwt. The difference imho is only the starting environment, which is perspective and the visual style is set to realistic.
When you started with acadiso you can always change that two settings and all is well 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
