ACAD Desktop file
ACAD Desktop file
cb94030
ACAD Desktop file
cb94030
I have customized all the icons that I use the most on my ACAD desktop computer.
I would like to have the same display as what I see on my new CAD laptop. What is the name and location of the file that I can copy from my desktop and paste to my laptop to see the same icons, etc.?
Thank you in advance!!
Chris B.
pendean
Community Legend
Community Legend
Depends, how well organized were you with crating/storing your customizations?
Or did you just modify what was there inside AutoCAD and not much else outside of it?
This is the better approach for 95% of users https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
TIA
cb94030
Thank you for your reply pandean!!!
All I want is to copy and paste the file where all my icons arrangements (on the desktop) are in one of the ACAD many files.
cb94030
Well, my question is: What file is that?
cadffm
Your way is not a good one, but i know that you can't learn all at the same time.
We all gone the hard way.
We can not know what you edited.
You ask for a file and i am pretty sure to know one file which incl. the most stuff,
but o like to give a better answer for your situation:
On both machines the same autocad?
The search in windows for: Export custom setting&files
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-i...
Another tip
Search for a document
Autodesk University CUIX
or
Autodesk University customization or similar.
..the best way is to keep all standards,
create your own stuff and just add them.
This way you can also setup newer program versions in Minutes
Sebastian
cb94030
Thank you CADffm!!!
