ACAD 2023 PressPull causes program to hang
BillAllenSE
BillAllenSE
While in my model, PressPull hangs.
It didn't do this before I created my first actual roof element. I also just installed the latest fix.
It hangs whether I select PressPull before or after I select the roof.
Am I doing something wrong?
Thank you
0 Me gusta
Responder
301 Vistas
3 Respuestas
Respuestas (3)
BillAllenSE
I haven't solved the problem, but I've solved some adjacent problems.
First, I made the 3D solid out of 2 parallel regions then used loft and sculpt to make the 3D solid. I could only get this element to Push-pull in the Z direction, perpendicular to the original surface. Instead, I created a 3d closed polyline of the cross section of the polyline which works fine.
I did some tuning on my graphics card and changed the 3d settings from best appearance to best performance. That helped quite a bit, but push-pull still takes some time to activate. Shouldn't happen on this small model. I have 2gb RAM and 4gb on my video card. It's an Nvidia T(?) 1000. Probably not acad certified, but should still be adequate for my models.
0 Me gusta
dw_cad
In AutoCAD 2025 for Mac I'm seeing a similar issue where AutoCAD becomes non-responsive when using PressPull.
Beach ball appears and force quit window says Not Responding.
Has happened twice. It recovered the first time after several minutes. But the second time it seemed to take a lot longer to recover. Something happens and the view re-renders.
Seems like selection goes into a state where more things are selected without obvious user intention. Unclear at this stage if it selected multiple things in a layer. The lines selected seem to be unrelated during the active PressPull. I've used PressPull before and it worked fine.
0 Me gusta
JOHNLLOYD7213
Press-pull is a very cheesy command. Sometimes it works, sometimes it doesn't. Often you have to force the selection of a surface with the control key. Sometimes only part of a surface extrudes, & often there are artifacts left at the original surface position - especially fillets. IMHO, the stretch command should be made to work in both 2D & 3D. It would certainly make generating eccentric reducers a whole lot easier. End of rant.
0 Me gusta
