Anuncios
ACAD 2021 XLINE Snap Problem
timothy_crouse
timothy_crouse
Does anyone have a suggestion for the following issue:
If I draw an XLine I can snap to it no problem.  If I put the XLine inside a dynamic block I can no longer snap to it.
Please see the attached block.
Thoughts?
Thanks in Advance
-Tim C.
0 Me gusta
Responder
436 Vistas
3 Respuestas
Respuestas (3)
imadHabash
when i open your dwg , a message appear ( [file name].dwg contains authoring elements. Open in Block Editor? )
i'm afraid that you have a problem in your dwg file . >> Click <<  also you don't need those long xline try to trim it or just use lines .
Imad Habash
0 Me gusta
cadffm
@timothy_crouse
This is righty,
but independed of xlines in dyn.Blocks ,
Xlines can force trouble also in normal blocks.
You can read about xline issues on AKN or in other forum posts.
@imadHabash
This message is normal if your modelspace incl. dynamic block parameter.
Open a new file an Insert this file as block.
Sebastian
0 Me gusta
timothy_crouse
0 Me gusta
