ACAD 2020 insert block *invalid*
Message 1 of 19
When I try to insert a block from my block library using ACAD 2020 I get the error *INVALID*.
I tried the classicinsert command with the same result.
I added the block's file location to support paths, no change.
I can open the block in 2020 just fine.  I tried saving it from 2020 and then inserting but I still get the *INVALID* error.
The blocks insert fine in ACAD 2018.  If I use 2018 to insert the block, and then (in 2020) use design center to pull the block from that drawing into a new drawing, it works fine.  Once the block is successfully inserted into the drawing, it will insert again.  However, if I use classicinsert to try to redefine the block (the new block palette grays out the "insert and redefine" and "redefine only" options), I get the *INVALID* error again.
How can I get my blocks to insert into 2020 using the new block palette and classicinsert instead of design center?
Replies (18)
Message 2 of 19
pendean
Community Legend
Community Legend
Share your DWG file source for your block tat does not work in 2020 but works fine in 2018.
Message 3 of 19
Every block I try behaves that way.  Here is an example of one.
Message 4 of 19
cadffm
Okay,
the uploaded file is not a library, but a dwg with dynamic parameters, so you can insert the file 'as block'.
I inserted the file via Designcenter, also via classicinsert and via a new created insertion tool inside my toolpalette (2020),
all works fine, no problems.
(on my version the BLOCK PERFORMANCE HOTFIX is NOT installed, do you installed the hotfix or not?)
It isn't a pure autocad file, so please tell us your productname&version (Command: ABOUT)
Sebastian
Message 5 of 19
cadffm
OFFTOPIC
@pendean
Congratulations PENDEAN to Rank 13 was time and looks very cool.
Sebastian
Message 6 of 19
when I referred to a library I just meant a folder full of .dwg files that I insert as blocks when needed.
For me, the only thing that worked was inserting from design center, but only after I inserted the block into another file using ACAD 2018.  I can't use design center to insert the blocks (.dwg files) directly.
I don't think I've installed the block performance hotfix, but maybe it was included in a service pack.  My product version suggests I haven't installed any service packs yet.  I install those from the Autodesk desktop app.  Maybe I installed the hotfix from there.  It shows that there are no updates available.  I didn't find a hotfix in my add or remove programs list.  I can't remember if they show up there or not.
I also use Plant 3D.  I may have worked on that block from Plant 3D 2018.  That might explain it not being a pure AutoCAD file.  There are other blocks in the "library" that I haven't edited and therefore don't think have been edited in Plant 3D.  There are a lot of civil 3D users in my company so maybe they've been edited with that.  The block I had provided may have also been edited/originally created with civil 3D.  Here is another block from the library that I tested with the same results (I haven't had any work yet, but I moved on after trying 5 or so).  I haven't edited this one, so it may be pure AutoCAD.
My product versions are:
     AutoCAD 2020 - Q.47.0.0 AutoCAD 2020
     AutoCAD Plant3D 2020 - N047.502 Autodesk AutoCAD Plant 3D 2020.0.1 Update
     AutoCAD 2018 - 0.161.0.0 AutoCAD 2018.1.2 Update
     AutoCAD Plant3D 2018 - K049.1510.r2.update Autodesk AutoCAD Plant 3D 2018.1.2 Update
They could have been worked on in any version of civil 3D or AutoCAD (or other things for that matter) at some point in the past.  The testing I have done since I noticed the issue has only been in AutoCAD 2020 and 2018.
Message 7 of 19
cadffm
Sorry, my mistake: I "installed" the BLOCK PERFORMANCE - 2020 HOTFIX (you not).
So please, install the hotfix before we searching the problem at another point.
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoc...
Your ACAD _VERNUM should be Q.48.0.0 then.
Sebastian
Message 8 of 19
I installed the hotfix (replaced the 2 .dll files in the location listed in the readme).  About still shows my version as 47.  I restarted the computer to see if about would update, but it did not.  I then tried to insert a block again but got the same error.
Message 9 of 19
cadffm
I don't know what you did, but you did it wrong.
I guess you replaced the files in the wrong folder, perhaps in the folder of 2018 instead of 2020 or similar like this.
You can see the accore.dll version number also by rightklick, properties , details, File version -> [23.1.] 47 or 48 [.0]
Sebastian
Message 10 of 19
see attached screenshots of .dll locations and accore.dll details and the about box and the properties of ACAD 2020 shortcut showing that the acad.exe is located in the same folder as accore.dll.
I don't know what I did either.
Message 11 of 19
cadffm
OMG
Please user the Command: _VERNUM
I am surprised that _vernum and _about display two difference values - my fail.
When _VERNUM display the 48 and it is still a issue,
it has nothing to do with the hotfix.
Last test before i say
- Repair-Installation
<save your current customatation/settings>
- Reset to default
- clean uninstall / clean re-install
- Re-install OS and all other programs
..argggh
Please start ACAD by this way:
[win]+[r]
open: "C:\Program Files\Autodesk\AutoCAD 2020\acad.exe" /product ACAD /p "Forum-Test1" /safemode /nohardware
Sebastian
Message 12 of 19
_VERNUM shows Q.48.0.0
win+r method gave me the same *invalid* error when I tried to insert.
I'll try to repair the installation tomorrow.
Message 13 of 19
cadffm
So the only thing i can say: It isn't a generally problem with the software product - because it is running on my side without a problem.
I am out.
Sebastian
Message 14 of 19
I ran an install repair on ACAD 2020.  The problem has changed now.  Some of the blocks that weren't inserting before insert fine now.  Some of the blocks behave in exactly the same way.  A lot of the blocks give me a different error now.  They now say *Invalid Block Name*.  So I followed the solution to the forum post:
https://forums.autodesk.com/t5/autocad-forum/error-when-inserting-block-invalid-block-name/td-p/8761...
and it worked.  But I don't want to have to fix every block that way.  The block that had worked for CADffm is the one that changed errors and I fixed.  Since it worked for CADffm without performing the fix, it should work for any good install.  So I will try reinstalling, and if that doesn't work uninstalling and installing fresh.  But I have to get some work done right now so that will have to wait.  I'll post my results after I have time to work at it more.
Message 15 of 19
cadffm
>" Since it worked for CADffm without performing the fix, "
Tested with and without that hotfix, multiple ways to insert and redefine - allways with success
win8.1, German AutoCAD
Sebastian
Message 16 of 19
I started messing with this issue again.  It would not reinstall, it gave me a file not found error.  So I uninstalled and reinstalled AutoCAD and Plant 3D 2020.  That reverted the problem back to how it behaved before I did the repair.  So I had the other CAD user in the office (who was on vacation during my initial struggles) attempt to insert the same blocks with 2020 and it worked fine for her.  So I guess there must be something wrong with my computer.  I just started working for this company 2 months ago and my computer does seem to have been around for a while.  There are remnants of several old versions of AutoCAD.  I'll ask IT if we can reimage the computer.  Maybe I'll get a new computer out of this.
Message 17 of 19
chris.weekes
For what it's worth, we have 2 users (including me!) with ACAD 2020 having the same problems here. Hope we find a fix soon.
Message 18 of 19
I did end up getting a new computer and it does not have this problem. The
old computer had a couple of other quirks as well. It had some minor
issues when printing pdfs that others didn't have and it couldn't open
certain zip files that others could.
I have no idea what caused this issue. I would guess it may be caused
somehow by the history of old versions of AutoCAD and other Autodesk
software having been installed, used, and then uninstalled when newer
versions were installed. That may have caused the other issues or they
could have been caused by something else related to the computer having
It may be worth trying to reimage a computer that is experiencing this
issue, especially if the computer has other issues. Since an uninstall and
reinstall didn't work for me, I don't believe it is an AutoCAD install
issue directly. But I would try uninstalling and reinstalling before doing
a reimage since that takes a while and you lose all the files on the
computer.
We are holding off on reimaging my old computer in case there are still
files I need. After a while, we do intend to reimage it and keep it for a
new CAD user if and when we bring one on board. I'll try to remember to
test the block insert afterwards to see if it remains.
Message 19 of 19
udo.huebner
Autodesk Support
Autodesk Support
Possibly it was related to an outdated Civil 3D Object Enabler when using AutoCAD or another vertical except Civil 3D.
This issue was fixed with the latest Civil Object enabler.
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-civil-3d-20...
If no Object Enabler is installed, this *invalid* block problem does not occur either.
And it only occurs with drawings/blocks that contain Civil/AEC Information.
