A viewport shows everything at an angle
yzhangMG49S
Observer
yzhangMG49S
Observer
Observer
I received drawings from a client and there are many viewports. In one viewport, everything seems to show at an angle. When I double-click to get inside the viewport, the 2D crosshair cursor becomes 3D cursor with three lines. The 3D cursor is still in color black though (not the green and red cursor). Anyone help me to make this viewport normal. Thank you!
vinodkl
Hello @yzhangMG49S
After activating the viewport, type in the command "PLAN" and press enter twice. This should set the UCS to current.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
yzhangMG49S
Observer
Observer
Seems to work for me. But it seems the viewport now zooms to extend and I need to adjust the scale and content. But regardless, everything is now normal without the angle. Thank you!!
pendean
Community Legend
Community Legend
@yzhangMG49S wrote:
...But it seems the viewport now zooms to extend and I need to adjust the scale and content...
Lock your viewport.
Enter your viewport.
Set UCSFOLLOW to 0 (that's a zero).
QSAVE your file.
Repeat for all other viewports in that DWG file's layouts.
In modelspace, if you don't need it, set UCSFOLLOW to 0 as well.
