A solid cannot be created.
maxim.gutter
maxim.gutter
Community Visitor
Community Visitor
Hello. I have a 3D-inclined polyline. How can I create a solid body from this line? I always end up with a surface.
tramber
Your object is not planar 😉
(my opinion, i saw only your Z values at each point)
Would it be, it could not become what we really call a solid body, only a planar one or a region.
Do you need some help to make it so ?
You can also treat by pairs of triangles.... a first step to where you seem to go....
parkr4st
attached with 3 objects 2 solids. one surface
one solid is 3dpolylines lofted along a 3dpoly central path
one is the right side a 3dpoly SWEEP on central most cross 3dpoly
THICKEN surface to 0.1 units
One is missing a small area at the lower end - may need a small solid unioned to it
suggest you experiment to get the wanted result
I like the curved surface best although it may not fit your needs
