Anuncios
A software problem has caused autocad to close unexpectedly: can't PLOT.
No aplicable
Hello guys. I'm having a pretty serious problem and can't figure out how to solve it. I'm using the student version of AutoCAD, and doing a job mapping two really big farms. They're about 35k hectares (86k acres) each, on separate files. The blueprint itself it's not really complex, but maybe a bit heavy. I have finished my job, but can't collect due to this problem when trying to plot.
I have tried on 6 different computers, purged, audited, exploded blocks, copied it into a new empty file, deactivated hardware accelerator, tried EXPORTPDF. Same result.
I uninstalled and reinstalled (2018 version), tried on 2020 and 2017's versions. Always the same sign when I hit Save: ''A software problem has caused autocad to close unexpectedly'' with both files.
I have no trouble on sharing the file uppon request, if you think you may solve it!
Cheers
Santiago
0 Me gusta
Responder
Soluciones aceptadas (1)
947 Vistas
5 Respuestas
Respuestas (5)
dmfrazier
Why not just send in the error report and see how Autodesk responds?
0 Me gusta
No aplicable
I did! They opened my ''case'' about four days ago and never replied.
0 Me gusta
dmfrazier
Try removing all page setups from the DWG(s) and then add back the one(s) you need.
0 Me gusta
No aplicable
Thanks but same result :cara_de_decepción:
0 Me gusta
No aplicable
Solución aceptada
Solved! I was able to plot by two means:
1) Downloading Autocad 2021
2) Downloading PDF Creator to convert.
0 Me gusta
