A hard part of a drawing
 I couldn't draw the highlighted part of this drawing. Can anybody help?
Replies (28)
JCKRU47
Is this a test part of some sort or are you making shop drawings? I wouldn't want to help in the wrong way depending on the situation.
this is just a practice given by my tutor.
JCKRU47
Gotcha. If it were me I would lay out a base sketch of the points you need, place and trim the circles you need, then rotate.
Thx
Kent1Cooper
You may not have enough information to really tie it down.  Can you assume that the transition between the R4 arc at the right end and the lower R22 arc is exactly vertically below the center of the R4 arc [i.e. at the intersection with the vertical center-line]?  It kind of looks that way, but maybe not....  If so, it should be determinate, but if not, it looks like there would be infinite possible solutions [though within a limited range].
Kent Cooper, AIA
RobDraw
What's up with the Ø4 and R10 on that part? It looks like they are pointing to similar arcs.
Rob
parkr4st
something like this?  offset 12, end circle, c  ttr small circle and offset line, c ttr big circle and circle centered on 0,0,0
trim and mirror, pedit , join  to complete
leeminardi
@RobDraw I think it is a poorly dimensioned drawing and that DIA 4 is the diameter of a knob measured at the minimum point of the R10 arc. The question I have is there a straight segment of the profile between the R10 and R22 arcs.  If so here's how I would construct the 2D outline.
  1. Create the R4 circle (after creating the diagonal line of symmetry).
  2. Create an offset line of 6 (12/2).
  3. Using TTR create R22 circle.
  4. Create an offset line of 2 (DIA4/2).
  5. TTR R10 circle referencing R12.5 circle, offset 2 line.
  6. Line tangent to R10 and R22.
  7. Trim as necessary.
lee.minardi
Kent1Cooper
@Kent1Cooper wrote:
....  Can you assume that the transition between the R4 arc at the right end and the lower R22 arc is exactly vertically below the center of the R4 arc [i.e. at the intersection with the vertical center-line]?  It kind of looks that way, but maybe not....  If so, it should be determinate....
That's not the answer.  It results in a "neck" size far smaller than their 4 units:
It's probably one of those things where you could get it to work to within whatever tolerance you prefer, but it may not be determinable with absolute precision.
Kent Cooper, AIA
Kent1Cooper
@leeminardi wrote:
  1. Create an offset line of 6 (12/2).
  2. Using TTR create R22 circle.
  3. Create an offset line of 2 (DIA4/2).
  4. TTR R10 circle referencing R12.5 circle, offset 2 line.
  5. Line tangent to R10 and R22.
  6. ....
It looks like a Line that the original doesn't mention [step 5 above] will be needed, because just Offsetting by 6 and 2 [yellow] and drawing TTR Circles results in a miss:
Kent Cooper, AIA
leeminardi
  6. ....
The step 5 line is circled below.
The final profile looks like this.
lee.minardi
JCKRU47
Kinda think a lot of people are over looking this. A lot of good advice, but in the end the objective from the tutor is to remake the part. So long as the answer gets a part that looks similar to the picture then @Anonymous get the answer the tutor is asking. there are a lot of different drafting questions and answers that can come from this one thing, but the main thing is that learning needs to happen and plenty of solutions have been provided to FIND an answer. That is what matters in the end is being able to find an answer.
leeminardi
@JCKRU47  I agree with you that a primary objective for the exercise is to use AutoCAD to create the geometry.  In the process the student should improve their knowledge of  AutoCAD and geometric construction techniques.  I disagree with your statement "So long as the answer gets a part that looks similar to the picture".  It is important for a student involved in the documentation of mechanical parts to understand that engineering drawings should not contain ambiguities. Two different machinist given the same drawing should not be able to create parts that are different from each other yet both parts meet the requirements of the drawing.  The fact that a drawing should completely define a part is a fundamental requirement of drafting and "close enough" (i.e., similar) is not good enough.  Exercises such as this one should reinforce, not detract, from this tenet.
lee.minardi
RobDraw
Well said.
Rob
JCKRU47
I completely agree with you. So far I have worked in fields that have allowed for such variance, but as drafters our goal is complete understanding and accuracy. I guess it's one of those cases where context really is everything.
Kent1Cooper
@leeminardi wrote:
.... engineering drawings should not contain ambiguities. Two different machinist given the same drawing should not be able to create parts that are different from each other yet both parts meet the requirements of the drawing. ....
Agreed.  For example, if some tangent LINEs are needed to make the dimensions work, in the absence of some indication that they're needed and where, who's to say whether this result [with magenta "closures"] or the one in Message 12 is "better"?
Kent Cooper, AIA
peterm
Of course it could be a rounding error and the thickness of the "handle" may actually be 12.27 (resultant dimension when all circles are tangent).
It doesn't even look as if that 12 dimension is placed at the widest part.
Kent1Cooper
I noticed that, too, and the Ø4 dimension seems similarly not quite at the narrowest part.
Kent Cooper, AIA
Vuxvix
If you post this topic a forum about geometry. Maybe it will be solved faster.
And if this is an exercise, how much time did you spend on it? For me it was 15 minutes, including presentation.
the picture is my hint
Ps:Looks like the litle is wrong. There is no arc tangent to 2 arcs R10 and R4 intersecting the line 6mm from the center.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
