64 bit os
64 bit os
No aplicable
trying to load up AutoCAD 2017( free student version) my system runs Windows 10 with 64 bit OS. AutoCAD installation starts up but there is no create deployment option I get just install tools and utilities. it starts to install then it stops and I get a "failed" message didn't finish downloading and installing
How do I fix this problem? any suggestions.
0 Me gusta
Responder
Soluciones aceptadas (2)
478 Vistas
5 Respuestas
Respuestas (5)
JDMather
@Anonymous wrote:
trying to load up AutoCAD 2017( free student version) ...
 didn't finish downloading and installing....
Are you trying to install Student license or Educational Institutional license?
Deployment option would be for institutional network license. Student license is single seat, not network.
Download the two files from here http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
0 Me gusta
TravisNave
Solución aceptada
JD is right.  You shouldn't be deploying anything.  Just install like normal.  If it fails installation, then post your installation log and we'll take a look at it.
In the mean-time, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Autodesk Forums:
0 Me gusta
JDMather
Solución aceptada
If you are looking for a free educational institution network license - check this link.
No aplicable
thank you Travis the suggestion you made in ref to using Virtual Assistance worked.
TravisNave
Excellent!  Glad you are up and running!
Autodesk Forums:
0 Me gusta
