5x12, 1/2 running bond
minfoogoop
Observer
minfoogoop
Observer
Observer
Hello, I would like to make a 5x12, 1/2 running bond, what is missing from the following code?
*5x12,
0, 0, 0, 0, 5
90, 0, 0, 5, 6, 5, -5
0 Me gusta
Responder
Soluciones aceptadas (1)
114 Vistas
1 Respuesta
Respuesta (1)
Kent1Cooper
Solución aceptada
If it's in a file of its own, the pattern name has to exactly match the file name [minus the .pat filetype ending].  And whether in a file of its own or added to AutoCAD's basic pattern file, if it's the last pattern definition in the file, it needs a blank line at the end, i.e. if you press Ctrl+End to go to the very end of the file, you should be at an empty line at the bottom, not at the end of the last line of code.
Kent Cooper, AIA
