48" x 96" acrylic cut sheet at 1:1 is not saving in true size in PDF
No aplicable
 I am drawing in 1:1 and plotting 1:1 save to pdf so it can be opened in illustrator to plot for lazor cutting BUT it keeps opening in illustrator it was on scaled to fit the size of paper and they could not scale it to the true size.  We have tried everything to get it to work.  What are we doing wrong.  We even change model space to 1/16 = 1' and still not luck.  Please help.
0 Me gusta
Responder
Soluciones aceptadas (1)
384 Vistas
3 Respuestas
Respuestas (3)
anas_hashmi
Maybe the problem is in the illustrator? I don't have illustrator so I cannot help you there.
However, I open the exported PDF in PDF viewer, something like Adobe.  The PDF viewer should be reporting the page size.  If the page size is 48" x 96", it is not the AutoCAD that is messed up.
0 Me gusta
pendean
Community Legend
Community Legend
Post your PDF, let's all have a look.
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I move things between AutoCAD and Illustrator quite often and have not experienced this  behavior. Can you attach your PDF so I can try it in my Illustrator?
Something else you can try is to just open the DWG file in Illustrator instead of going to PDF  first. Does that work properly?
John Vellek
