3DClip Issue
3DClip Issue
lbellino4
3DClip Issue
lbellino4
Hello.
I have used this command before and never had an issue until now. I used it in a drawing on a page and it was fine. I sent this drawing to another associate that removed it on the page per suggestions from our manager. Well now, the drawing came back to me and I need to add it back. I created a new viewport and did the 3D clip as I normally do, and it's not working where I need to see the section view of the stairs. I've attached images showing how it looked before it was removed from the sheet and after when I created a new one to add back to the sheet. I checked the 3D clip settings in both viewports and they are the same. So I'm not sure what settings I need to change to fix this. The only change I know that has happened to my computer is that I installed the latest version of AutoCAD 2021, which is what I'm now using vs. 2019 that I was using.  Any idea on what's going on here and how to fix? I've already closed out my CAD and reopened it and rebooted my computer and neither fixed the issue. Thanks in advance for your help.
imadHabash
i suggest to check if any updates needed from your Autodesk Desktop App .
Imad Habash
lbellino4
Already did that and it did not fix the issue. Sorry for not mentioning that in my original post.
