Anuncios
3D Seashell
3D Seashell
No aplicable
Hi everybody,
I need to draw a 3D model of a seashell based on a 3D scan of a granite ornament.
I've tried a sweep, but I keep getting error codes because the path's startpoint has a differtent Z-value then the endpoint. The profile of the sweep also should become smaller.
Anybody have any idea's how to go about this?
I don't have a license for Inventor, only Revit and Autocad.
I've sent some screenshots to give you an idea of the project.
0 Me gusta
Responder
812 Vistas
3 Respuestas
Respuestas (3)
natasha.l
Hello @Anonymous,
It is likely an issue with the orientation of the object & the UCS. Try creating the object following this process & UCS set up beforehand then conduct the sweep.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
beyoungjr
Create your spiral path in WCS (World Coordinate System).
Create your full size seashell cross section closed profile in the Front UCS.
COPY the full size cross section then scale it down by .75 or whatever you wish.
Return to WCS and MOVE you full size profile to the outer start of spiral and your smaller profile to the inner end of spiral.
LOFT those along the spiral as your path.  They will loft to one another uniformly.
Sample Attached
Blaine Young
Senior Engineering Technician, US Army
No aplicable
Hey,
Thank you all for the advice. I managed to create the seashell in Revit with a swept blend.
A little tweaking in autocad and finished!!
gtrs
0 Me gusta
