3D Rotate Settings
3D Rotate Settings
lbellino4
3D Rotate Settings
lbellino4
Hello.
This just happened when I opened AutoCAD today. When I click on any item in my drawing, it activates the 3D rotate lines, but does not activate the command itself. I'm sure it's a setting that I need to change, but not sure where to fix. Any suggestions? Also, is there a link or another post to reference for basic commands that I should know for different types of settings that I can change in AutoCAD? Thanks.
imadHabash
>> is there a link or another post to reference for basic commands that I should know for different types of settings that I can change in AutoCAD? <<
there is a lot of settings and system variables that by experience and through daily use you will know it and understand it.almost every command have it's own settings and HELP (F1) is the best documented place for that.
draw a line in a new blank drawing and please confirm if this happened again.
Imad Habash
lbellino4
When I closed out of ACAD and reopened it, that seemed to fix the problem. Must have been a kink in ACAD at that time. Thanks for the help.
