@scott_bolton,
I converted your 3D polyline into a solid. See attached. I guessed at the extrusion distance.
Steps I used to create the solid:
- EXTRUDE the 3D polyline. This create a surface extrusion.
- SURFPATCH
- Use CHAIN option to select edges along top of surface extrusion.
- ENTER to accept the default surface
- This creates the second surface
- SURFPATCH
- Use CURVE option to select original 3D polyline.
- This creates the third surface.
- SURFSCULPT
- Select the three surfaces (extrusion and two patch surfaces).
On my PC, it took about two minutes to complete the patching steps and then another five minutes to complete the sculpting step. The sculpt operation joins the surfaces to make a solid.
I hope this is understandable. I have included a simple example of the progression steps.
Please mark as accepted if this answers your request.
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
