3d poly to non planar surface
BB8x
BB8x
Hello
How can I create surface from attached 3d poly? I am a newbie with surfaces and trying for 2 hours and can not.  Normally I would hand draw planar 3d poly - triangle and convtosurface
Additional question: how can I draw planar surface (3 points in 3D) just by clicking in the drawing?
imadHabash
you must have a planar object ( No Z values ) , if you notice that AutoCAD will till you that if you run PLANESURF command ... '' Cannot convert a non-planar curve. '' .
 PLANESURF command, planar surfaces can be created from multiple closed objects and the edges of surface or solid objects. During creation, you can specify the tangency and bulge magnitude.  for more information you can follow this link . >> Click <<
Imad Habash
