3D orbit and other 3D manipulating methods-Solid disappears at the beginning
Karol-Or
Karol-Or
I press the middle mouse button+Shift and the model rotates, O.k. but immediately as i start rotating the solid disappears and i zoom to extents to find it.
It happens also when i start the 3D orbit command.
0 Me gusta
Responder
2.164 Vistas
17 Respuestas
Respuestas (17)
Slawomir_
try to change visual style.
0 Me gusta
Alfred.NESWADBA
have you tried to select the object (or objects) before you start orbiting, by default AutoCAD will then hold the center of that objects as fixed center of orbiting.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Karol-Or
When first i select a solid and then orbit it behaves the same as when not selecting-it moves much out of the view.
How can i control how much it moves as a function of the mouse?
How can i make that the orbit center, as you say, will be in the solid i selected? which variable stores it?
Changing the visual style doesn't change anything.
0 Me gusta
Alfred.NESWADBA
Look to the sysvar ORBITAUTOTARGET (>>>details<<<).
If that does not help and this issue only appears in that one drawing, then please upload the drawing so we can look into the details about that 3D Solid.
- alfred -
Alfred NESWADBA
Karol-Or
Here is what happens when i start the 3D Orbit, the model jumps.
There is no sys var ORBITAUTOTARGET but there is Enable Auto Target on the shortcut menu during the 3D Orbit command. i used it but it doesn't help.
Alao, the model gets stuck in some positions, i can't rotate any more
0 Me gusta
imadHabash
how about 3DORBITCTR command.
Imad Habash
0 Me gusta
Karol-Or
3DORBITCTR doesn't help. but it's strange, the first time i used it it was O.K., the model rotated without jumping to some position at the beginning.
But look also what happens when i try to rotate more-i can't.
I recorded a screencast, it said it's been uploaded but it's not in the list.
As soon as it wil be i will attach
0 Me gusta
imadHabash
just to remind... please if your model far a way from 0,0,0 please move it near to 0,0,0 and see how it's work.
Imad Habash
0 Me gusta
Karol-Or
Now you can see how it gets stuck.
The WCS is near the model
0 Me gusta
imadHabash
>> Now you can see how it gets stuck. <<
honestly... i review your screencast many times and i don't see any stuck..
Imad Habash
0 Me gusta
Karol-Or
It doesn't stuck, i can rotate all the time but it gets locked in 2 positions: horizontal in both directions: the TOP and BOTTOM views, and even though i drag the mouse the model doesn't continue. i can only rotate between those 2 views.
I attached a simplified file.
0 Me gusta
imadHabash
There is a toolbar called Orbit as you see in my attached screencast and there is 3 types of orbit. are they ok for your issue.:)
>> Screencast <<
Imad Habash
0 Me gusta
Karol-Or
In constrained orbit it doesn't work as in your screencast, but in free orbit yes
0 Me gusta
Slawomir_
Press Shift+W, press and hold Orbit.
SteeringWheels
0 Me gusta
Karol-Or
With the SteeringWheel it works fine, it doesn't jump. and it also works with Freeorbit, but with Constrained orbit it jumps as i press the mouse button.
And, also, the rotation of the model is constrained between 2 states, as i said.
0 Me gusta
LS67
This also happens to me but only when i have external references set to a layer that is frozen.
It takes for ever for the 3DO to execute for the first time, i press escape, it resumes with no graphics, when i quit the command i see the graphics.
The next time i try the 3DO it works instantly but it shows no objects until i quit the command.
Thawing the layer that contains the external reference everything works as expected.
0 Me gusta
abdelhalim.bousmaha
One of the solutions is:
command: GRAPHICCONFIG  ---> In Effects Settings switch off Hardware Acceleration.
0 Me gusta
